Hey everyone,
Is there any way to export rhino lights to max and v-ray. I tried many formats but all of them skipped the lights. As you can see, there a lot of windows to be illuminated and I am not expert in max to make them there with preciseness.
Anyway, emissive material in max (v-ray) should me much faster than adding so many lights and with the right setup and you should get a good result, it’s a common technique. You could use a main or key light for the global and an emmisive shader as an effect
