Hi all,
Is it possible export Rhino layers info into Maya? Thanks!
-Kev
Hi all,
-Kev
Should be possible via IGES - no?
āMitch
Hi Mitch,
Yeah. I did a little research on this but no luckā¦
http://wiki.bk.tudelft.nl/toi-pedia/Export_Rhino_to_Maya
Maya reads IGES file as an error file. (I gave up ) I tried OBJ format later on and It did export layers but not the way I want to see. It exports as meshes and I need to reorganize layers in Maya. Itās such a pain doing texture work in Maya this way. So what is causing that red error message in Maya? Can you see what steps I missed? Thanks
Demo
http://www.screencast.com/t/CYEBxOrT
-Kev
Did you ever find out how to import it into maya? I have the same question. Please help me out if you figured it out!
No, sorryā¦
I guess those who have good knowledge in scripting can do thisā¦
Strange it works fine on me? which Maya version do u use? the best way to send Rhino file to maya is via Iges. to retain the NURBS.
it transfers Layer attributes, as well as Shading group. if your intent is to texture in Maya then there is no need to actually bother about the layer. We use Layer in Maya for display purposes only.
since you get the shading group from Rhino, you can texture them by selecting Object via āOutLinerā and āHyperShadeā
note that u need to use a little MELscript to fix the Layer Name in Maya. and delete some useless junk in Outliner (empty sets) and also, Maya imports Rhino World coordinate as one transform node called āworld1ā better delete it too.
4 NURBS Solid in Rhino, assigned to 4 different layer.
Export via Iges and Import in Maya. On the outliner, delete the useless node to keep everything organized
Open HyperShade and Start to Texture from Shading Group
any question feel free to ask.
Cheers.
*I just realized the post is from 2 years ago, so probably a little bit too late to reply this
Maya didnāt read nurbs object that time. I did try IGES export from Rhinocerosā¦
What is your email address? I can share you model link, would be great if you can try.
And, do you know a way to match Rhino camera view to maya?
Thanksā¦
I have never tried to import Rhino Cam to Maya. but theoretically, you can copy and paste Rhino (Cam,Target xyz position + lens length value) to Maya Camera Attributes. and u ll get the same result.
other option =
this guy seems to have written a GH def. to automate the whole process =
Iāll send u a PM
