How to edit imported mesh file, an obj. made in Blender - advise needed
Hi!
I helped a friend to convert an obj-file from Blender to a 3dm-file in Rhino.
It is supposed to be manufactured and the file used to create a mold.
My friend received a sms from the factory today that says (see pic):
Here is a view in Rhino of the model, it consist of 8 700 000 polygons:
How can I edit/format it so it meets their request?
Kind regards/ Jonas
it sounds like the factory need Nurbs files and you sent them a mesh.
this is a reverse engineering job.
see this video on how to use quadremesh and subd to do this in rhino 8, or look up a plugin called rhino reverse for more detailed reverse engineering tools.
Thanks a lot for the fast reply! I will look into it and try to solve it. Kind regards/ Jonas
Jonas,
There are a few issues related to converting an organic mesh such as this to nurbs:
  • Detail is typically smoothed, this may or may not be an issue depending on your expectations
  • Large numbers of nurbs surfaces can be generated, which may pose a problem for some CAM systems.
  • Offsets from the nurbs surfaces may be problematic due to the complexity and / or minimum radius of curvature.
Thanks for the input! Im helping a friend out, so I will try and convert it to Nurbs and see how it comes out, then he has to decide if he want to proceed with it. Its nice with such a helpful forum as McNeels :slight_smile:
