How to edit an stl file
Hi, I tried one of the MESH edit tools under the MESH menu but I can’t remember which one. Please let me know if there’s an easy way to convert a mesh object into lines that I can then turn control points on for and reshape. Thanks! --Susan
Hi Susan,
You do not need to convert the mesh, just use PointsOn to turn the control points of all mesh surfaces on. It will be a tedious job to edit it though, don’t forget to select ALL of the points coming together at a particular knot, otherwise the integrity of the closed mesh will be corrupted.
Max.
