I am trying to make a shape look the same in both sides (I made it by lofting semi-circles) but the only way I know to do this only by moving this control points but it seems not able to deliver a good enough result. I want to bend this shape like the blue line.
The other question is about drawing around surfaces.
Hi Leonardo - it’s always best to send the objects you are asking about as a Rhino file when possible. I am not sure if I understand the second question, but perhaps the Project command is what you are looking for, maybe with History.
Leonardo, can you please post just the curves and the resulting surface that you do not like? I am not sure what I am looking for in the file you sent.
You may need OffsetCrvOnSrf for the second question, but I am still not sure if I get it @giuseppe , can you take a look?
Hi Leonardo - what curves generated this surface? I’d like to reproduce your process to see if I can make a suggestion for making it better - is this the set of curves you are working with?:
