How to draw arc with specific requirements correct?
Hi guys,
I’m stuck on something which seems embarrassingly simple and am hoping for somebody to give me the obvious answer so I can facepalm myself.
So I’m trying to draw and Arc with the following conditions:
With the Arc command I can get quite close using “Startpoint” and then set the direction at the start to be continuous from the straight line. But when I then want to use the “Tangent” snap for the endpoint, it doesn’t want to snap so I never get a 100% correct solution:
Enlighten me please.
Yeah, you can get there but it is not ‘face-palm’ territory.
Put on End Osnap
Start Arc > Tangent and hover over the line near the end so that the tangent indicator and End osnap are showing and click. At the command line, set ‘FromFirstPoint’ then drag over to the circle and click when you see the tangent marker.
Thanks @pascal !
