How to draw a line with a specific degree in Rhino
Hello
like the title says how can I draw a line with a specific degree in Rhino
Hi Tugba- do you mean degree as in Nurbs curve degree, or degree as angle? To draw a line at an angle, use the < symbol before entering the second point.
<30 for example.
You can also add a distance constraint to set the length:
<30 10
Use ChangeDegree to set the degree of a line or curve once created.
I’m having some issues with this in use. What is the baseline degree if you are looking at a world plane? Is it to the right? When I try to rotate something and use the <67 command, it definitely does NOT rotate from my previous point, it rotates from some world defined degree preset. Does this make sense?
Hello - zero degrees is at “3 o’clock” and + is counter clockwise. But ff you are using the Rotate command, it rotates with the starting locations as zero.
@Brennan_Aitken-Gantz
Here’s a link to the section in the User’s Guide tutorials that covers this subject:
http://docs.mcneel.com/rhino/6/usersguide/en-us/html/ch-05_accuratemodeling.htm
