Is there any way of selecting an object and getting its overall X Y Z dimensions without having to use dimensions tool ?
Steve
Steve
Hi Steve - Use BoundingBox
with output set to None - the command line will report the size, or use BoxEdit.
Bounding box / BoxEdit are both working on world / Cplane orientation , in case of object in space, dimensions will be only returned as aligned world/Cplane box.
I really would like to see a Minimum bounding box option to calculate the real maximum/minimum size of objects.
You can try MinBox script made by Thomas An.
http://www.rayflectar.com/p04-Programming/programming.html
