To see the dimensions of a clicked object without entering a command. Is it possible?
Select Object OnSelect Event
Rhino.StatusBarMessage Object.Width Height Length Debth
Is that a feature request?
I don’t know of anything that would automatically display this info in the status bar just by clicking on the object. That’s a lot of info there to display in a tiny area…
BoundingBoxWithSizeOnScreen.py (4.8 KB)
But you still have to click a button or type an alias to run the script on a selected object.
Hi @ska_drivers, you might try below script. Run it once to enable, run it again to stop:
DimensionInfo.py (1.5 KB)
_
c.
Hi @ska_drivers,
it should give you the same Z since corners 0,1,2,3 are all at the same height.
box.Min is number 0
_
c.
It gave incorrect results in DX or DY values.
bbox = Rhino.Geometry.BoundingBox.Unset
for rh_obj in rh_objs:
bbox.Union(rh_obj.Geometry.GetBoundingBox(False))
x = abs(bbox.Max.X - bbox.Min.X)
y = abs(bbox.Max.Y - bbox.Min.Y)
z = abs(bbox.Max.Z - bbox.Min.Z)
I changed these lines
better not use rs methods in event delegates. You can see if this give the results you expect:
def MyDimensionInfoEvent(sender, e):
rh_objs = list(scriptcontext.doc.Objects.GetSelectedObjects(False, False))
if not rh_objs:
Rhino.UI.StatusBar.ClearMessagePane()
return
bbox.Union(rh_obj.Geometry.GetBoundingBox(True))
x = bbox.PointAt(0,0,0).DistanceTo(bbox.PointAt(1,0,0))
y = bbox.PointAt(0,0,0).DistanceTo(bbox.PointAt(0,1,0))
z = bbox.PointAt(0,0,0).DistanceTo(bbox.PointAt(0,0,1))
units = scriptcontext.doc.GetUnitSystemName(True, False, False, False)
message = "DX={0:.3f} DY={1:.3f} DZ={2:.3f} ({3})".format(x, y, z, units)
Rhino.UI.StatusBar.SetMessagePane(message)
it will run slower of course. Try with millions of objects.
_
c.
please post an example where it failed using:
_
c.
Please upload this curve so i can check.
thanks,
c.
DimTest.3dm (63.7 KB)
CLEMENT
Thank you very much.
