I am completely new to Rhino- Have been using Vectorworks- I am wondering if there is a way to always see the dimensions of any selected object- ie. its width/height/extrusion etc. None of this appears in the ‘details’ of the Object info. Thanks
Hi Helen - no… but you can get the overall dimension info using the BoundingBox command (also various anlaysis commands like Distance, Length, etc) Using BoundingBox with output set to None means you’ll just get the report of the BB size and extents but no box will be added.
Thank you I will try that!
