How to delete Rhino Time Machine / autosave versions on Mac?
I’ve noticed my Rhino files keep saving backups through time machine crazily often (Mac, Rhino8), and I think its eating up a huge amount of my system data storage (100gb+)
I’ve tried the File > Revert To which should give me the option to delete past files but I don’t have a delete anywhere?
I don’t have Time Machine set up anyway on my Mac so it sends me in a loop when I try to access it, it asks me to add backup disk which I don’t want / need to do
I’ve since turned on TestToggleMacAutosaveVersions to disable autosaves, and also gone into advanced settings and turned off autosaves - not sure if this will work (I’m confident about saving iterations and rather manage my own backups manually)
Any idea how to clear the rhino time machine files?
Hi Sophia -
That is completely handled by macOS. As far as I know, older versions are automatically deleted as time goes on. Since you have turned off macOS versioning for Rhino, I would assume that all older version will, at some point, be gone. For more information, you’d have to search or ask on a macOS forum.
Hi Sophia,
I’ve had the same issue recently and I found an app called The Revisionist which is able to delete past versions of all kinds of files, including Rhino.
Another tip I found is to only save your files when you close them - and never while working on them - because auto backups are frequent enough that even if your program crashes, you’re not gonna lose anything. Saving a file manually (Cmd + S) creates a duplicate of the file with all past versions. I work 10 hours in Rhino on a daily basis and my storage was filling up rapidly in my brand new Macbook. And I’m talking 200GB in under 2 weeks.
These files are accumulating in the Revisions-V100 folder on your Mac where you can delete them manually as well, though you should be very cautious doing so because it can break certain program’s behaviour.
These are the soludtions I found on my deep dive on the topic, hope they help!
