4 of 5 supports have displacements and rotations, and when Karamba runs the analysis, it has difficulty finding stability. I have to reset the Analysis component several times until stability is achieved.
Is there an option that prevents this behavior? I mean, for one beam it is not a problem, but if there are dozens of similar beams, Karamba is not able to find stability for multiple of them
Just to explain it a bit more, I am also able to get it to work, it’s just that I need to disable/enable the Analysis component several times until I get some meaningful results
thanks for the bug report! I tested your definition with Karamba3D 3.1.60309 and RH8. There seems to be a problem with the prescribed displacement load which on my machine results in a wrong result after every 20th recomputation or so.
I opened an issue here.
I will try to fix this.
