How to create this triangular gradient pattern
Hi everyone,
I’m trying to recreate a triangular gradient pattern in Grasshopper, similar to the image attached. The triangles appear to:
  1. Follow a structured triangular grid.
  2. Gradually rotate and scale based on an attractor curve or field.
  3. Fade out towards the edges, reducing density.
I want to define a boundary and use a curve to control the gradient transformation. How should I approach this in Grasshopper? Which components or logic would be best for achieving this effect?
Any help or suggestions would be greatly appreciated!
Thanks in advance!
Hello
you will find on this forum and old forum a lot of elements.
You can use google like that in order to find more easily
here some links
