How to create surface between two curves?
Hello, I am trying to create a surface between these two curves. I try the
boundary surface but it wasn’t working.
Try loft
Works with Boundary Surfaces if you flatten inputs to Merge component.
Note that output of Merge component is a DataTree if you don’t flatten inputs. In this case, the Boundary Surfaces component produces two separate surfaces.
You will also have to flatten inputs to use the Loft component.
-Kevin
