Hi, this might be simple, but I’m just not seeing it.
What I want is to create a surface between two closed curves, two ellipses, one big, one small.
Somehow the Boundary surfaces component creates one big surface. I am able to do this with other closer planar curves, but in this specific instance it doesn’t want to work. I’m lost as to what the cause is, please see the enclosed file and the screenshot. There isn’t anything else to explain I think.
My goal is to create a surface in-between the two curves.
Ah you’re right, there is something with the curves. To be precise, the 7th curve;
I generate the curves by creating multiple polygons, and then raising the fillet to the point where they become circles. I do this because I want the option to also be able to turn them into a square, triangle, hexagon, etc.
