Just wondering how can we create this curve at the intersection between horizontal and vertical planes. Please note that the wall is slightly slanted and has curved at the corner.
The curved at the intersection will have to wrap around the corner for continuity.
Tried this with blend but it was unsightly cause the command create a slight fold in the joint. Fillet didn’t work either because it is one direction only so it doesn’t wrap around the corner.
Is there a way to solve this without creating a 3rd element between the planes and shape it? There must be a simpler way to this but I am not sure what.
Hello - Untrim that vertical fillet - this is really not that hard. You need two surfaces that are close enough together to fit the fillet at the radius you want.
