Hello, I am trying to fillet the corner of this surface but cannot figure out what command should use. Any idea? Thank you.Test.3dm (88.8 KB)
Hello - in this case, âFilletâ the edge curves, then Trim
the surface with the resulting curves. Since the edges are not planar, the Fillet
command will not work. You can use BlendCrv and and adjust the curves by eye. To get a consistent setback to the the blends, make a sphere centered on the edge end points.
A trick is to ExtrudeSrf
the surface as a solid and then FilletEdge
the vertical edges, then ExtractSrf
the surface you want and delete the rest.
FilletTest_PG.3dm (41.7 KB)
I have an old vb script that fillets non-planar curves, Iâll try to dig it up or write it in Python.
@hungwai.lim, @norbert_geelen - in case it helps, this thing does, or tries to do, curve fillets for curves not in plane - if you give it edge curves, currently it will only make the fillet curve, but free curves as inputs should obey the trim and join options.
Note you can use it to make a âfilletâ between two lines that cross without intersecting:
or for making non-rational fillets in the regular planar case as well.
See if it does anything you like.
To use the Python script use RunPythonScript
, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
FIlletNonPlanar.py (10.8 KB)
You canât fillet single surfaces. You could thicken it then solid fillet the corners.
I tried BlendCrv but cannot find an easy way to do it precisely, the sphere is a good trick. Thicken the surface is also works. Thanks a lot!
Wich is a shame, really.
I know a cornerfillet and cornerblend command for surfaces would make my life easier for sure.
Norbert
@norbert_geelen, @Stratosfear, @hungwai.lim - hereâs a first try at that - see how this one works for what you need:
FIlletSrfCorner.py (9.0 KB)
, or a macro:
The fillet will only appear arc-like from a particular view or plane - I added options to use the World or CPlanes as the basis for the arc shape but this might make a mess pretty easily if the chosen plane is too skewed from the ânaturalâ fillet plane. The Auto option attempts to find this natural plane and should probably be used most often. Iâm not sure how useful the other plane options are, I was thinking that one might, for example, want the fillet arc to appear âtrueâ viewed from the top and not from the surface tangent plane there, so that is what the plane option allowsâŚ
Making an exact raduis corner cut of a surface could be done this way, too:
- Use the âFinâ command (Extrude curve normal to surface) to extrude the two adjacent edges around the corner.
- Then use âVariableFilletSrfâ (Variable radius surface fillet) to create the desired radius fillet.
- Untrim the latter with the âUntrimâ command (sometimes that step is not necessary).
- Use the fillet surface to trim the surface edge.
I think itâs the better way and simplyâŚ
