How to Create a Smooth, Organic Leather Texture?
I originally planned to use Grasshopper, but I’m concerned that the high mesh density required for this kind of effect might put too much strain on my computer. I then spent several days experimenting with Substance Designer, but I still haven’t been able to achieve the result I’m looking for.
Ideally, I’d like to create a seamless, tileable texture that can be repeated in both directions. If achieving a fully seamless pattern is too difficult, I’d also be happy to start with a smaller, standalone texture or model that can be repeated to create a larger surface.
Does anyone have any suggestions for a suitable workflow, techniques, or tutorials? I’d also really appreciate recommendations for other software or alternative approaches that might be better suited to this kind of effect.
Thank you so much for your help!
Image 1 shows the smooth, organic effect I’m aiming for, while Image 2 shows the result I’ve achieved so far.
The top image shows the Voronoi-like pattern I created, while the bottom image shows the cell-like structure I’m trying to achieve.
Have you seen this post? Leather looks a little different to the plant cells, but the principle is the same.
You can get a seamless pattern/tile by taking a given set of points for the main pattern, and duplicating it right, left, top, and bottom so the tiles edges match up
I think the trick to getting the cells to look like the leather sample is figuring out the logic behind how to best manipulate the input point cloud to get the right look. In the case of the plant cells, they are sort of squished in one dimension so the cells end up looking long and skinny, and fairly uniform. The leather example has far more variety in scale and shape.
I hadn’t seen this post before, but it’s given me some ideas. Thank you so much!
The file in this post shows how you can create a seamless voronoi loop.
