Hi I created a mesh with RV2, and I want to know how I can convert it into a smooth polysurface. (without the triangular cut, so having rectangular opening)
My rhino version is 7.17
TOSurface.3dm (1.9 MB)
Hello- convert is probably not an option but you can certainly build surfaces using the mesh as reference. Another possibility is to Join
all the meshes, Weld
and then QuadRemesh
to about 1200 polys and SubD output - then you’ll need to Bridge
across the V shaped cuts.
Thanks for your quick response, It comes quite close to what I wish to achieve thanks!
One additional think that I want is this: (image below) - that the opening starts from the rectangle and the crease gets gradually smoothed out. Would it be also possible to achieve it with SubD as well? If so, how?
You can do that using SubD and adding some creases
Yes that is what I tried, but it didn’t make a smooth transition, the transition was very short that way
One additional think that I want is this: (image below) - that the opening starts from the rectangle and the crease gets gradually smoothed out. Would it be also possible to achieve it with SubD as well? If so, how? @pascal
Similar topic, same user
How to convert Mesh to a smooth Polysurface - Grasshopper - McNeel Forum
Found a way, I just manually adjusted control points. But let me know if you guys have any better solution!
You have too many subdivisions, working with a Subd…
test1.3dm (125.0 KB)
currently this is the only way to do fading creases in rhino 7
the slide command in box mode will be your friend in doing this.
