Im trying to do a voronoi façade on my subd volume. How can I transform my SUBD multipipe to NURBS?
Here’s a simple script (1 line):
subD_to_brep.gh (88.4 KB)
It just calls the RhinoCommon SubD.ToBrep(SubDToBrepOptions) method with the supplied options.
-Kevin
maybe there is something that i am not understandig. I am geting a brep output in the exemple, but i actually need a surface output. Am I letting something pass?
A brep can be a single surface or a polysurface. In this case, it is probably a polysurface (multiple surfaces joined together).
The script output should be the same as baking your SubD to Rhino and running the _ToNURBS command.
-Kevin
So i cant transform subd multipipes to surface?
It is not possible to make a branching structure like the one in your picture from a single surface.
Your multipipe structure can be converted from SubD to a brep but it will be a polysurface (multiple joined surfaces).
-Kevin
