Convert : polysurface to subD
Hello
How do you convert a polysurface(NURBS) to subD in Rhino 8?
And subD to polysurface(NURBS), to make edits , without gridding the surfaces?
Thanks
you can run the tosubd command, but it won’t do what you are expecting.
use the quadremesh command on the polysurface then use the tosubd command.
converting a subd to polysurface via the tonurbs command
Is there a specific way to work with subD and polysurface (nurbs) together? Editing with the tools of both resources alternately?
Thanks
at the moment no… working in subd then converting to nurbs to finish up is a common workflow, but going back to subd is not as easy.
it tends to be a one way street.
tell me more about what you are trying to make?
I’m not doing anything
it’s more about getting to know the available tools.
thanks
cool- check out these videos-
