example:A➡B
mesh23.gh (13.4 KB)
Your mesh is pretty messy, but here’s a quick brute force approach (that stills has several triangles):
Thank you very much! This is a model export from tekla, and I will study how to merge triangles again.
Something like this:
Merging the faces could last an eternity, if there is a lot of them.
private void RunScript(Mesh x, object y, ref object A)
var brep = Brep.CreateFromMesh(x, true);
brep.MergeCoplanarFaces(0.01);
A = brep;
Better from tekla you can export to sketchup format, then import to rhino as “Trimmed planes”. It will create brep in Rhino.
There is a process for exporting solids out of Tekla
Thank you for your advice. I’ll try it.
Thanks to your algorithm,which solved my problem.
Thank you very much.
Thank you for your reply. I’ll try to learn.
