How to close surface properly
hi
i created an object with twist and flow along curve.
and in the end its not closed Properly.
this is a surface.
how can i closed it?
please help.:confused:
thanks:slight_smile:
You could try matching the surface or splitting it at the two points highlighted and then blending/lofting the surfaces
This looks like where I would use ‘joinedge’ and I know Pascal doesn’t like that.
Hi Al - it looks at least possible that MatchSrf - for tangency, probably - may fix it.
thanks everyone for the help! :grinning:
2DCube, thank you for the explanation.
it is working fine now.
:grinning:
:slight_smile:
hi 2dcube
how can i split at the two highliphted lines?
You can either use ExtractIsocurve (toggle) and Split or right click on the Split icon:
For that to work you may need to explode some of your model - make sure you have the knot object snap on too.
Andy
thanks! :slight_smile:
