How to close a Brep ( cap holes?)
Hi,cap holes.3dm (41.0 KB)
cap holes.gh (11.7 KB)
I tried to “cap holes” and “cap holes Ex” but it doesn’t work, I didn’t know where is the problem. when i do set one geometry it works and i get a closed brep , but when i did set multiple geometries it doesn’t work and that means i can’t count the volume. ^^
You have 2 curves on top of each other in your rhino file which causes problem. Delete one of them and your definition works.
you are right, thank you
I have the same problem, could someone please help me?
Script Ônibus - P.O.gh (26.1 KB)
Not really the same problem, but if you feed the curves from your Region Difference component through a Boundary Surfaces component before you extrude them you get closed breps.
-Kevin
