A portion of extrusion resulted in open breps.I want to use these breps for solid difference but grasshopper doesnt yield any difference with open breps.How can ı turn these open breps to closed breps.
Cap might do it.
clean tree might remove the first error.
Does CAP work if you bake the objects first? i believe it only works on planar holes, fyi
Am I right to assume this is a QR code extruded from 2d squares? I would suggest solving these issues in 2d first. Try region union (curveboolean in rhino). Since your cubes have many coplanar faces, simplifying as much as possible upstream will give you a better chance of success at the 3d solid difference stage.
