I remember it had a choice for me the choose rhino 7 or 8 when launching Revit. Now the option is gone, how can I get the option back?
Hi I am using Revit 2024 and Rhin.Inside.Revit version:
Hi @newshunhk,
in case it helps. I just installed Rhino.Inside.Revit 1.18 and I got the option to choose the Rhino version. For context: before I had the same Rhino.Inside.Revit version as you 1.16 and I had both Rhino 7 and Rhino 8, but I was not getting the option to choose, only when I installed version 1.18. If I remember correctly what I read, it is because Rhino 8 can only work with Rhino.Inside.Revit 1.18 or newer, but I am sure @Japhy knows more.
thanks! since Rhino.Inside.Revit 1.18 crush with one of my existing plugin, so I switch back to 1.16 ![]()
There is something that I have done to avoid this, because I have the same problem with some plugins too (Speckle and ClimateStudio). I have three different version of Revit (22, 23 and 24). In Revit 22, I have activated Rhino 8, while in Revit 23 and 24 I decided to keep Rhino 7. I know it is not ideal, but I can use the solution as a placeholder for now.
how can you choose which rhino to launch?
@newshunhk, please forget what I said
. If you have both versions of Rhino (7 and 8), you will always get the option to choose which Rhino version you want to use every time you start Revit.
