I have a question I can’t solve. I started my rhino model with meters but it needed to be centimeters, so I changed the units to centimeters ( unit settings) but my text unit is still on meters eventhough I changed to centimeters? How can I change it to centimeters?
You didn’t supply enough detail to know.
When you changed Units, did you say Yes to scaling? Yes would mean, “I messed up and thought I was modeling in centimeters”. No would be used when, “I knew I was in meters but need to switch to centimeters”.
The next step is to go modify the named dimension styles you’re using. They were originally set up to work correctly with Meters from the template file. Then will need to be adjusted for the new unit change.
You can change the unit in Options -> Doc Properties -> Units to centimeters.
A another good approach, is to model in one unit system and dimension in another.
You can create a dimension style that has text that represents the part in centimeters, even thought the model unit is meter. See the attached example 3DM.
If you have a model that is not changing unit when you select it, please post it or email tech@mcneel.com.
We are happy to take a look at it.
I forget to open small objects- centimeters, so when I noticed that I waited till I had everything done so I can scale it to meters, but didn’t find to do so, but thanks for your answer!
Yes, Look on the TextField dialog - (From annotation dialogs, click fx)
DimArea doesn’t do it automatically, but you can edit the text or make a new leader with an Area text field.
I am trying to dimension for a particular floor plan in square meters. So, for that particular dimensions, I would like it to be shown in sqm, while the rest of the dimensions are shown in mm…
if I change the units of the whole document, then is scales everything, unless you are able to change it for that specific part?
