Hi! I’m trying to analyse a frame of Curtain Wall with Karamba and I have a question about loads.
Generally the wind load is represented as a trapezoidal load when it is applied to the mullion and as a triangular load when applied to the transom. (Figure 1)
I’m a beginner in Karamba and I’m not sure how to set loads other than rectangular.
I read throught Karamba’s manual, but it is not specified.
Dear Sonia Ruta,
at the moment (Karamba3D 1.3.1) there are only constant loads available for beams.
As a workaround you could split the beams in small pieces and approximate the linear change using constant loads on these
Best,
Clemens
To my knowledge it is not possible, for this kind of case I use loads by points, and I define a relation on grasshooper to have a variable value along the beam… (boring…)
