How to alter a closed polysurface?!
Hi there,
i have these two halves of a bean, and the rim around it needs to be wider, but i dont know how to alter it as its all a closed polysurface and i didnt have history on. I tried exploding it which allowed me to delete the rim and i thought i’ll just do it again with different measurements but the whole thing is open and wont join together. i don’t want to have to re create the whole thing just to increase the rim by 0.25mm! i must be missing something! you can see in the second screenshot the gap in the middle
Hey Jennifer,
you can dupedge and get a curve from the edge of your polysurface. Then offset it by the amount you need to make it wider (2.5mm)
Then offset that curve inwards the amount you need for thickness of the rim. (or copy the existing curve that make up your existing rim)
then make a planar surface from those two curves and extrude it into the new rim.
then boolean it into your existing object.
if you share your file, I’ll be happy to demo this.
