Hi!
I’m trying to create a loft between two meshes but the result is not good. I tried following advice from other posts but still nothing. Can somebody help me explaining what’s happening and how can I fix it?
MESH_LOFT.gh (133.0 KB)
Hi!
Awesome! That worked perfectly. Thanks a lot René!
Hey René, quick question. Do you know why if I join all the meshes it says it’s not solid and you can see that a quad is different?
Normals needed to be unified too:
MESH_LOFT.gh (136.7 KB)
*This can be done a bit smarter but edge line directions need to be checked/adjusted first so there’s no need to unify later.
Sweet! Again, this worked perfectly. It was also driving me crazy because when I added this to a larger definition the top mesh was being duplicated at the end but I found the problem. Thanks a lot for your patience!
