I would like to ask how can I correctly loft two closed polylines into mesh, that shading would be right?
In the code below I have polylines that has a correct corresponding order of points, so they loft in a good way.
Then I create faces in between. The mesh seems right. But the shading not. How can I correctly create a mesh that shading would be right?
Unify normals and other cleaning functions not helping much.
public static Mesh Loft(Polyline[] twoPolys, double weld, bool cap = true) {
Mesh mesh = new Mesh();
mesh.Vertices.AddVertices(twoPolys[0]);
mesh.Vertices.AddVertices(twoPolys[1]);
if (cap)
Mesh Top = MeshCreate.MeshFromPolylines(new[] {twoPolys[0]}, weld);
Polyline p = new Polyline(twoPolys[1]);
p.CollapseShortSegments(Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance);
Mesh Bottom = Mesh.CreateFromClosedPolyline(p);
Bottom.Flip(true, true, true);
int[] tempV = Enumerable.Range(0, Bottom.Vertices.Count).ToArray();
int[] tempF = Enumerable.Range(0, Bottom.Faces.Count).ToArray();
Bottom.Ngons.AddNgon(MeshNgon.Create(tempV, tempF));
Bottom.Normals.ComputeNormals();
int n = twoPolys[1].Count;
if (twoPolys[0].Count >= 2)
int f = mesh.Faces.Count - 1;
if (twoPolys[0].Count == twoPolys[1].Count)
for (int j = 0; j < n - 1; j++)
mesh.Faces.AddFace( n + j, n + j + 1, j + 1, j );
f++;
mesh.Ngons.AddNgon(MeshNgon.Create(new[] { n + j, n + j + 1, j + 1, j }, new[] {f}));
mesh.Append(Top);
mesh.Append(Bottom);
else
if (twoPolys[0].Count >= 2) {
for (int j = 0; j < n - 1; j++) {
f++;
mesh.Ngons.AddNgon(MeshNgon.Create(new[] { n + j,n + j + 1, j + 1, j }, new[] { f }));
//This is optional.
if (weld > 0)
mesh.WeldFull(weld);
else
mesh.Flip(true,true,true);
return mesh;
