V5
What is best method to align the objects in detail view to each other if they are all at 1:1 scale ?
I need to align the objects in left, front and right views.
Method 1. If I activate a detail view and right mouse button shove hand, then repeat on next adjacent pane, I am doing it by eye.
If I wish to do so up close, zoom in first then activate else the scale changes !
Method 2. If I activate and select the objects they get moved in the modelling views, oops, dont want that.
Method 3. If I select the inactive pane, then use move tool, perhaps some temporary lines, then I have to reposition the pane border using control points whilst that leaves the object where I moved it to.
I dont want to move things in the modelling views.
so is method 3 the only way to align objects in layout view ?
Steve
