Rhino Layout and detailed view
I was wondering if there was an option or a plug in to have the detailed views in your layout follow a geometry in the viewport so that if you move your elements in the viewport the detailed view would follow that geometry.
Thanks in advance,
Paul
Hi Paul -
There is no such option, no, and I’m not aware of a plug-in that does that.
Okay thanks
Hi Paul - would you expect the view, relative to the object, to stay as it was? Presumably yes… that is, if an object were in the corner of a detail, should it stay there on updating, or is the object always centered? Presumably you’d get to designate one object per detail that gets tracked, if the view needs to stay constant.
