i download and make 3d model but i have doubt in adding material
what if interior wall one material and external wall one material
how to edit matterial of 3d model.3dm (238.0 KB)
Hi @from_outland
I’m guessing this is imported from eg. Sketchup or similar. The objects you have here are blocks, and inside those blocks are meshes. In order to assign individual materials to mesh faces, you need to extract the faces, meaning you have to split the mesh in two (or however many different materials you want). You can either dbl-click to edit the block and extract the individual faces/mesh parts, or you can explode the block using ExplodeBlock and go from there (and note, that if you do use ExplodeBlock here, some of the objects will have their normals inverted; use Flip to fix that). Use ExtractMeshFaces or ExtractMeshPart to separate the selected mesh faces from the rest.
If these were NURBS objects, you can assign individual materials to individual faces by sub-object selecting the faces (by using selection filters or by shift+ctrl clicking them) and simply assign the material to just the selected faces.
Last, if you wathyou are talking about is assigning different materials to each side of a single face, you can use the Double Sided material:
HTH, Jakob
yes SketchUp
The normals (what Rhino considers the outside/inside of a surface) are flipped. Use Flip to revert them.
BR, Jakob
Edit: And for the missing materials, just find them in the material tab and re-assign them.
WHAT I WANT TO DO
------HOW TO EDIT EXSITED COLOR MODIFIED LIKE DARK GREY TO LIGHT GREY LIKE MATERIAL EDIT AND CHANGE TOP TABLE COLOUR DIFFERENT LIKE RED or green
and
What you are showing here is a material that uses a texture map (which for some reason isn’t embedded in your file, so in the video I’ve replaced it with something fairly similar) and the colour of that bitmap can’t be changed in Rhino. You’ll have to use Photoshop/Gimp/weapon of choice for that. Alternatively you remove the texture in the material panel and either replace it with a texture of the right colour/material or simply use a colour, see video.
As previously stated, these objects are meshes, and you have to extract the faces - assigning materials to subobjects only works on NURBS objects (and Sub-D’s).
-Jakob
