How to add components to the canvas using Rhino Python
I’m currently testing Rhino and Grasshopper. In one of my tests I’m opening a Grasshopper document from outside (Rhino) using Python. Then I would like to add components and connect their outputs to the nodes of the opened document (active canvas). So far I managed to open the GH document and created a slider, but I couldn’t find a way to add another component like a “curve_primitive_polygon” onto the canvas. Every example I found, creates a slider which is part of the Grasshopper.Kernel.Special library. In the future I would like to add custom, native and plugin components to the canvas and connect them. Is this even possible?
Have you checked this one?
Here is a small example for Rhino Python:
Farhad
import clr
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\CurveComponents.gha")
from CurveComponents import Component_Polygon, Component_OffsetCurve
from Grasshopper import Instances
from System.Drawing import PointF
gh = rs.GetPlugInObject('Grasshopper')
if gh.IsEditorLoaded():
    doc = Instances.ActiveCanvas.Document
    if doc:
        polygon_comp = Component_Polygon()
        polygon_comp.CreateAttributes()
        polygon_comp.Attributes.Pivot = PointF(100, 100)
        doc.AddObject(polygon_comp, False)
        offset_comp = Component_OffsetCurve()
        offset_comp.CreateAttributes()
        offset_comp.Attributes.Pivot = PointF(200, 100)
        doc.AddObject(offset_comp, False)
        offset_comp.Params.Input[0].AddSource(polygon_comp.Params.Output[0])
        gh.RunSolver(True)
Farhad.py (915 Bytes)
I was not aware that the Components need to be referenced. Your snippet is very helpful.
Thank you @Mahdiyar !
It’s also possible to add components using their GUIDs’, Here is another example using InstantiateNewObject.
Farhad
import clr
from Grasshopper import Instances, Kernel
from System import Guid, Drawing
polygon_component_id = '845527a6-5cea-4ae9-a667-96ae1667a4e8'
offset_instance_id = '2eeaae3b-3de0-4d80-9707-29d7b9a60700'
    canvas = Instances.ActiveCanvas
    if canvas:
        canvas.InstantiateNewObject(Guid(polygon_component_id), Drawing.PointF(100,100), True)
        polygon_comp = canvas.Document.Objects[canvas.Document.Objects.Count-1]
        offset_comp = canvas.Document.FindObject(Guid(offset_instance_id), True)
        gh.RunSolver(True)
In this example I tried to show how you can do that, obviously you need to know the Instance GUID of the target object; Here is a small C# components that helps you find this kind of information:
GUID
GUID.gh (3.2 KB)
Thank you very much @Mahdiyar. Your examples are very insightful. Much appreciated!
