Adding component to canvas by name?
Hello
How to add a component by name to the canvas?
This way didn’t work
tofind = Rhino.NodeInCode.Components.FindComponent("MassAddition")
comp = Grasshopper.Instances.ActiveCanvas.Document.FindComponent(tofind.ComponentGuid)
How to get list from NodeInCode.NodeInCodeTable()
table = Rhino.NodeInCode.NodeInCodeTable()
table.GetDynamicMemberNames()
<System.Linq.OrderedEnumerable`2[[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]] object at 0x00000000000000C6 [System.Linq.OrderedEnumerable`2[System.String,System.String]]>
I tried with c# but no result
    Rhino.NodeInCode.NodeInCodeTable table = new Rhino.NodeInCode.NodeInCodeTable();
    var enumerator = table.GetDynamicMemberNames().GetEnumerator();
    List<string> names = new List<string>();
    while (enumerator.MoveNext())
      names.Add(enumerator.Current);
    A = names;
The method you want to use is Grasshopper.Instances.ActiveCanvas.InstantiateNewObject
2022-12-26 03_00_52-Window
create GH component from name.gh (3.6 KB)
code:
  private void RunScript(string name, bool go)
    if(wasgo & !go){
      id = Rhino.NodeInCode.Components.FindComponent(name).ComponentGuid;
      wasgo = false;
      GrasshopperDocument.ScheduleSolution(5, CreateComponent);
    }else{
      if(go)wasgo = true;
  // <Custom additional code>
  bool wasgo;
  System.Guid id;
  private void CreateComponent(GH_Document doc){
    Grasshopper.Instances.ActiveCanvas.InstantiateNewObject(id, new System.Drawing.PointF(0, 0), true);
Also:
create GH component from guid.gh (7.1 KB)
Thanks @maje90
Yes i found it in another thread and i used it
And this works faster and don’t need SheduleSolution
import Grasshopper as gh
import System
import clr
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\CurveComponents.gha")
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\MathComponents.gha")
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\SurfaceComponents.gha")
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\TriangulationComponents.gha")
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\VectorComponents.gha")
clr.AddReferenceToFileAndPath(r"C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components\XformComponents.gha")
import CurveComponents,MathComponents,SurfaceComponents,TriangulationComponents,VectorComponents,XformComponents
doc = gh.Instances.ActiveCanvas.Document
comp = CurveComponents.Component_Arc()
comp.CreateAttributes()
comp.Attributes.Pivot = System.Drawing.PointF(pt.X*10,-pt.Y*10)
if x:
    doc.AddObject(comp, False)
