GH Python : Create, Connect and delete components in canvas
I’m working on a script to instantiate different connected objects (either with a specific name or in a group) a dynamic number of times (depending on a slider value).
My first approach is to on a slider change (delayed value compared with actual one):
  • delete all existing objects starting with a given name
  • get the objects to create
  • create these objects n times
  • connect them correctly
Can this be done using the python component?
I’m able to get the objects, but do not know how to delete/add or connect them…
Best regards
import Grasshopper as gh
ghObjects = ghenv.Component.OnPingDocument().Objects
if number != number_before:
    for idx, obj in enumerate(ghObjects):
        if obj.NickName.startswith("ADD_"):
            print(obj.NickName)
Hi
Yes it’s possible to do what you want,if you search in forum you can find pieces of code you are looking for and then combine them.( Like this : Bringing Fun to Workflow: "TTP224" in Grasshopper)
Hello sadra,
thanks for the quick reply. Yes it seems that you are doing part of it in video 2. But all the code I’m able to find in the forum is related to Rhino objects and not grasshopper components.
Hello sadra,
work is progressing, but I still face a issue:
  • I get this error after one run
"""Grasshopper Script"""
from System import Guid, Drawing
components_to_delete = []
components_to_add = []
doc = gh.Instances.ActiveCanvas.Document
    for obj in doc.Objects:
            components_to_delete.append(obj.Attributes.InstanceGuid)
        if obj.NickName.startswith("XXX_"):
            obj_coord = obj.Attributes.Pivot
            for i in range(0, int(number)):
                obj_dict = dict(name = str(obj.NickName).replace("XXX", "ADD_"+str(i)), guid = str(obj.ComponentGuid), x = obj_coord.X+int(offset_x), y = obj_coord.Y+200*(i+1))
                components_to_add.append(obj_dict)
    for comp in components_to_delete:
        delete = ghenv.Component.OnPingDocument().FindObject(comp, True)
        doc.RemoveObject(delete, True)
    canvas = gh.Instances.ActiveCanvas
    if number > 0:
        for comp in components_to_add:
            canvas.InstantiateNewObject(Guid(comp['guid']), Drawing.PointF(comp['x'],comp['y']), True)
            canvas.Document.Objects[canvas.Document.Objects.Count-1].NickName = comp['name']
a = "Done"
My code(for video 2) is very simple but can give you some ideas :
import System
import System.Drawing as sd
ghdoc = ghenv.Component.OnPingDocument()
oh1 = gh.Instances.ActiveCanvas.Viewport.MidPoint
def createSlider():
    mySlider = gh.Kernel.Special.GH_ParamViewer()
    mySlider.CreateAttributes()
    mySlider.Attributes.Pivot = System.Drawing.PointF(oh1.X,oh1.Y)
    return mySlider
you can check topics like this : Modify Wires after instantiate component - #2 by Mahdiyar
Hi, why doesn´t work this code in rhino 8?
