How can I randomly level out a floor created with diamond panels. All with points and lines.
I need to create with line because I have to indicate to the CNC drill where to go.
Thanks you very much.
prueba1_3d.gh (13.6 KB)
Hello
you didn’t internalize a geometry !!
It is not clear what you want. Can you draw something ?
Thanks Laurent for helping me, i want to elevate this point randomly. Creating a diferent lines in the 3d space. Because that lines will be the line that will follow the CNC into the piece of material. (a wood block)
Elevate this points creating a surface with spaces, but all with points and lines.
If you want to move the curve Point Deform is the component to use
thanks a lot laurent, serious
hello, help
Hello
I understand english is not your native language, use a translator to have clear question. Just saying “Hello help” is far from clear.
