How should I go about trimming several triangles out of this trangulated surface?
#1
I created a complex surface by lofting several curves together. I then triangulated this curve with the intention on fabricating it by eventually unrolling it with Ivy. I triangulated it with a tutorial I watched on Designalyze, but if there is a simpler way (I’m pretty sure there is), then please feel free to share the solution. I included a screen shot of the components I used to triangulate my curved surface.
Anyways, based on an attractor curve, I’m offsetting the triangulated surface edges a given amount, and I wish to trim these triangles out of each triangulated surface. This is what I’m having a hard time figuring out. I’ve tried doing a surface split selecting my surface component and the offset edges, but I have not had any luck yet. I also tried to do a surface brep split, but also to no avail.
(David Rutten) #2
Nobody can really help you without the file. Have a look here to see how to best prep a file for public upload.
If your data is organised correctly, then you should be able to create a datatree which has individual lists containing only the triangular outline and the triangular cutting curves per panel. These lists can then be turned into panels using the Boundary Surface component.
#3
But you didn’t post your solution as a code file?
#4
My apologies. My file is now attached.2018.04.05_mcneel_forum.gh (55.2 KB)
#5
Cutting is computationally expensive, so it is best to avoid it if possible. In your case you can create a loft between each pair of triangles or better yet, use Boundary Surfaces if they are coplanar. But since you want to make it thicker/print it/to use ivy, it’s easier to make it with meshes, so here you go, I hope it works for you.
2018.04.05_mcneel_forum.gh (79.5 KB)
#6
Also, besides Ivy, Lunchbox plugin has some pretty handy features for you…
TriGridPanelFacade_re.gh (22.2 KB)
