Trim a curve from another curves
grass 3.3dm (26.0 KB)
grass 3.gh (12.0 KB)
I make this box with curves and i want to split the triangle curve from the box but not like a surface. I want to extrude the surfaces. What do you you thinki can do? I tried to trim ans spli it but it trims as a surface and i can not do the extrude i want on the curves
Thank You
GB
there is a very useful component called “Split with Brep” that does exactly what you are looking for
