I am used to using the middle mouse on PC to open the floating PopUp window for the last 20 years. I cannot live without the PopUp.
Now I am on the Mac and use the wonderful Magic Mouse so there is no middle button option.
(I would have loved to use my left button to remedy the problem, but that button cannot, for some reason, be customised.)
Therefore I have had the PopUp remain permanently visible on the middle of the screen in order to survive. Well, now it it has disappeared and I cannot find a way to make it appear again.
CommandSearch only offers “Popup Popular” which is not what I want. I just want the good old PopUp.
I can paste “_ShowToolPalette _ToolPalette=Popup _Visible=_Toggle UnderCursor=Yes AsMenu=No Enter”, but that does not allow the Popup to remain visible.
So, how can I make the Popup appear? Where is the thing hidden??
(Also haven’t found a way to make a Keyboard shortcut for this either.)
You can create an alias (preferences) for a single character you have not yet used for another alias (just for convenience, can be a multi character alias as well) with this macro: _ShowToolPalette _ToolPalette=Popup _UnderCursor=YES _Enter
Go to Preferences > Themes. In stead of “Rhino for Mac” choose “Custom”. Check box “Show top tool palette”.
Show palette “Popup”. The Popup palette will show up as a toolbar on top of the window.
That did it.
I wonder why the Popup is not showing in the command search, though.
Seems hard to find considering the benefits it has for a more efficient workflow.
It is like it has been forgotten, almost, or deemed unworthy…
Sadly the Popup is not retrievable in this way any more. I have gone through the same process, but no Popup, even after restarting. And even it it would work it seems a stretch to jump through hoops to display the Popup - defeats the purpose, no?
Just to clarify: The Popup does show on the Standard tab-ribbon, but not as a floating tool palette. Meaning I must constantly move the mouse up to the ribbon and not only operate in the central region of the window as when using a floating tool pallette.
For anyone still looking for an answer: You can create custom gesture macros on MacBook for the trackpad. It’s in Options → Trackpad. In there just put the macro “poptoolbar popup” for the gesture you’d like to use. I put mine on three finger left swipe.
Hope this still helps someone, since this is the first result on google.
