Hello ![]()
I’m trying to do the same thing as Offset Surfaces on a mash, I’ve tried a few techniques in Rhino and grasshopper but without any significant success.
My goal is to use the outline of my mash and slide it inwards into the shape so that I get a clear boundary that I can divide.
Thanks for the help.
Cool problem - post a file ![]()
You can do that with Kangaroo and the on mesh goal.
I was going to suggest exactly that or, if the ‘mesh’ is planar or simple enough, reinterpret as surface, perform the OffsetOnSrf + MeshMap.
What are you going to do with the curve afterwards? What’s the overall goal?
I want to split the mesh into two parts: a variable border line (we are currently trying to create the inner line of this part), and a central surface.
I need to work on them separately later.
…mesh
If you want any help please share a file and a Rhino file which shows the expected result or at least a sketch.
