Been searching here and through the reference, and tried a few GH components… but I’m stuck.
Three of these curves are being generated from GH; I’ve drawn the original.
Thanks!
Thanks!
you can Connect Curves on the Merged original curve and its flipped offset
There is a Join curve component to which you can connect your 4 curves. But better it is to use a Merge component to merge these 4 curves, and then use a Flatten node into a single data tree that you can attach to the Join curve.
Thanks guys -
I tried figuring out both these things before posting, but haven’t gotten any combination to work yet.
What components should I be using? Merge doesn’t let multiple curves be connected. Neither does Flatten, so I assume I need a list or something.
Not sure what you mean by "its flipped offset”.
Connect_Curves.gh (12.7 KB)
check the gh file attached at the end of my post
