How do I join the 3 ends of the subd?
I’m trying to join these 3 components into a smooth subD, but just could’t find the way
Maybe insert some loops to then bridge the edges?
basically what @Lagom suggested with a few steps showns. bridge each segment or 2 segments as shown in the 2nd image, you might have more so you either use insertedge or you remove some with control shift double click which will select the entire row then delete.
to finish up left over holes use fill or rebuild to match the edges.
after some rebuilding, this topography might be better.
