How do I handle Sweep2 problems? Srf Blending problem
Hello there, rhino beginner here :slight_smile:
I have a more or less complected cross-section where 3 blended surfaces meet each other.
With my last Sweep2 command I now get this surface blending problem:
what is causing this artifact?
here is the file in case you want to take a closer look.
Sweep2 Problem.3dm (518.6 KB)
Thanks for helping!
Hi Niklas - it looks like those edges there are slightly out of tolerance and not joined. You can clean up like so:
RemoveMultiKnot and MakeUniform that corner surface to simplify it somewhat.
MatchSrf the edge that looks funny for tangency
Then MatchSrf the outer edge as well:
(Note! different settings)
Then join and I think it looks OK
Thank you!! I just forgot to check for “naked edges” :smiling_face_with_tear:
