Hi there,
I’m trying to model an Imac.
I’m still at the beginning with the stand. Now the stand does not have a continuous height of 2 cm, but gets higher and higher towards the back. How do I create this slope?
I hope you understand how I mean it ![]()
Hi there,
You could use CageEdit with 2 points in each direction. Or you could use Taper.
I get the same result when I use Taper
I don’t know what result you are getting. You can extrude your shape higher than you want it and then trim it with a line. Is that what you need?
If you look at the photo then the stand at the rounded edges is relatively thin and then becomes thicker towards the back. But I only get the result as I posted at the beginning of this post
Hello - draw the curves in ‘side’ view and Shear like so,
The curves can then be lofted together.
Tapered.3dm (117.2 KB)
