How do I create a texture on a surface?
How do I create a texture on a surface similar to to the rings I have attached?
Thank you for any help.
-Daniel
Hi Daniel - FlowAlongSrf of a flat pattern or ApplyDisplacement using a grayscale bitmap are the two things that tend to come to mind for this type of thing. For the full spheres. FlowAlongSrf is the only workable option I’d think. See Help for this command - that will give you an idea how to go about using it.
Thank you very much, I will look into those.
u can achieve the same with vector displacement map on any rendering software (for the full sphere one)
