Ive tried to remove crease and weld the vertices no luck, and rebridge
Please try to using the RepairSubD command to fix this issue. If there is still a problem, pls share this 3dm file. Thanks.
Thanks Jessesn
can i ask how you broke this in the first place? or does anyone know a good way to break a subd, so that the repairsubd command will fix? im trying to make a demo video for this command, but can’t figure out how to break it for fixing in the first place. thanks
create defect
_unweldEdge
repair
I hate that rhino has merge, weld, join, sitch.
I would love to see a “smart-glue” command that guesses the most valid workflow under the hood…
my preferred workflow for subd / cases like this:
randomly pick / subselect edges or vertices
Gumball-move them to make the problem visible.
(this will allow correct selection)
then _stich
_stich is the most powerfull tool and this workflow will fit for most situations - you might need to combine it with deleting micro-slim-faces…
make it worse before stitch
(see also this topic)
no Idea
Thanks mate
solved ?
