I’m trying to close a voronoi pattern using a custom surface boundary. As you can see with the first image the pattern has open curves on both and top and bottom of the surface boundary. The logic I used was to try and split the surface boundary curves and join them to the voronoi pattern, but my attempts have been unsuccessful. I also can’t simply use the close curve component has I have filleted areas which doesn’t align perfectly with the boundary.
Open curves at the top and bottom of the pattern:
Base surface boundary highlight in blue:
Close curve result not following filleted areas:
I will provide my attempt in the script where I got close but struggled with the data management to finalise the result:
GH Script: Rock_Wall_Help.gh (57.4 KB)
Thanks!
