How can I project something into something else?
let’s say that I make a box, then I want to project whatever thing I’m drawing in one face of the box, but while I’m drawing it, and not after that I finished the drawing, as if I was using the project box under the snap settings
the problem of the
, is that it seems that it is snapping the curves/thing, into a predefined plane…
to project a curve onto a object, you should be using the -project command in the view you want the direction of projection.
the menu you mad a screenshot from is for snapping. the snapping points are projected to the construction plane of your view.
hope that helps
B
Hi -
I’m assuming you are drawing a curve - start the Curve command and then hover over the Osnap panel. Hit the Ctrl key. The snaps will change into a number of one-shot and persistent options - select the POnSrf option. You will then be asked for a surface to constrain the mouse picks to.
